Additional lift
Please settle a dispute between my friend and I. He has a 2.5" Rubicon Express lift and wants to add 1" spacers for additional lift. I told him that he can not do that. He stated that the guy whom installed the lift stated it can be done. Anybody ever hear of this?
I actually have a 1" spacer in the rear of mine and it has a 2.5" coil lift.
no reason why you can't do it but, with more lift come new problems (driveline clearance issues, angles, suspension and steering geometry, need for longer shocks, brakelines, recentering your axles, caster, etc.) that, while not required, i would highly recommend that you address.
Spacers are actually much better for adding an inch to the top of healthy springs than for making up an inch on overloaded or sagging springs - so I'd say give it a try. As WOL said, be prepared for other issues when you go taller.
