Jks disconnects maintanence
Old Aug 9, 2012 | 04:43 AM
jeepwave's Avatar
Default Jks disconnects maintanence
Just wondering how to maintain/lubricate these? Mine are much stiffer than before. I noticed they have nipples of some sort. I'm assuming these should be greased? If so, what do you use?
Old Aug 9, 2012 | 05:27 AM
Atch's Avatar
Oh yeah, you need to grease them, I grease mine every couple of months. I use whatever jks recommended, can't remember what type of grease it is though.
Old Aug 9, 2012 | 06:36 AM
Pghchamp's Avatar
I just bought a cheap grease gun and grease them at least once a month. Takes 2 seconds to do. Those bushing seem to dry real quick
Old Aug 9, 2012 | 08:06 AM
Czep's Avatar
As said above they tend to dry quick. I grease mine after every wheeling trip.
Old Aug 9, 2012 | 08:20 AM
rtguy1's Avatar
those red caps are covering the zerk grease fitting. they need to be greased very often when new for break in then every oil change a pump or two per the instructions. any common axle/bearing grease is fine.
Old Aug 9, 2012 | 02:49 PM
JK UNLIMITED's Avatar
JKS reccomends standard wheel bearing grease I decided to use synthetic wheel bearing grease and it works awesome but you do need to keep up on greasing them at least every oil change!
Old Aug 9, 2012 | 03:18 PM
jeepwave's Avatar
Cool...thanks for the info guys. I figured, just wasn't sure what grease to buy.
