EVO Lifts-Coil Over or Double D Long Arm?
With all the excitement about the new bolt on coil overs that Offroad Evolution is now offering I started looking at these with the other hundred thousand Jeepers out there. I see that EVO also offers their Double D Long Arm suspension. Is one better than the other? What are the differences?
I looked at the cost for the Bolt ons (front and back) + drag link flip kit + front LCAs and the price is about $4300. The price of the Double D kit is $4359 with the King shocks. So the price is about the same for either set up.
Any opinions? Thanks for the input.
One is set up with long arms, Coils and Shocks, The other is short arms and coil overs. Coilovers will give you adjustable ride height, Dual rate coils, increased flex over the Double D system.
On the other hand the Double D with King shocks will still ride really nice, Less control arm bind (comparing johnny joints to torsion rubber on the stock arms). Its a tough one. I Personally went with the Bolt on coilovers and stock control arm set up. Down the road I can upgrade to the long arms system and have the best of both worlds.
Originally Posted by chris@offroadevolution
You are not really comparing apples to apples...
So you can run stock control arms with the new bolt on coil overs?
Originally Posted by matprovo
I knew I was missing something. Thanks.
Not to hijack, but I've been trying to research as much as possible on the new bolt on coilover setups ....
In addition to eventually replacing the stock control arms with a long arm system, what else should one be prepared to upgrade or replace? I've got a 2012 JKU, so I know the front driveshaft is a must.
PS: I know the long arm isn't a must, but it's definitely something I'd want to do shortly down the road.
Damn those guys at EVO do some amazing work. I will be going with coil overs once I have some more money to throw at my JKU...course Im now considering the double thowdown...sigh! too many options!
BTKillerr
BTKillerr
Hey Matt, thanks for dropping by and helpin' out...after you left we installed everything back up no problems whatsoever and even test drove it around couple blocks...soooo smooooth!
here is some flex with stock control arms and the rear set not presently on the jeep!
