drive shaft rubs on the oil/trans skid
I installed a rugged ridge oil/trans skid and after 3 days of wheeling my front drive shaft started rubbing on the bracket that goes from the engine mount to the skid. It happens when at full compress of the front. going in a hole or going over a speed hump where the front dips down. It is a 2010 rubi 2dr and has a 2.5 BB, procomp shocks and new sway bar links. Any ideas, everything is tight and looks lined up. Have not had the aliment done yet to check it by something other then the human eye for being lined up. We have 5,000 miles on it.
Originally Posted by plntman
dont want to grind it and it be caused by something else that i am missing if all other options dont work i will look into grinding.
Grinding is way cheaper than a new drive line. You can grind a little and check it then grind some more if needed. Use a soft disc/flapper wheel and the grinded area will look smooth and pretty.
