lift kit
Old Aug 12, 2012 | 12:25 PM
saharaboy's Avatar
Default lift kit
can anyone tell me if this kit has everything i need or are there other parts i need to buy
3.5" Series II Suspension Lift Kit for 07 and up Jeep JK Wrangler by Rough Country
Old Aug 12, 2012 | 12:34 PM
06jeep65's Avatar
If you have a 2012 you will need an exhaust extension
Old Aug 12, 2012 | 12:38 PM
saharaboy's Avatar
i have a 2011, so would there be nothing else that i need
Old Aug 12, 2012 | 01:02 PM
Blakspire's Avatar
Everything is there. Drivelines recommended, not needed.
Old Aug 12, 2012 | 01:03 PM
gunbo75's Avatar
Yep front drive shaft sooner or later if you have a automatic. I have a 3. 5 lift and I tore my boot on the transmission.I have a jku a two door will have a more steeper angle than a four door.
Old Aug 12, 2012 | 01:28 PM
saharaboy's Avatar
thanks a lot! would it be possible for you to post a link of what i should get
Old Aug 12, 2012 | 01:40 PM
Croce's Avatar
I have it and love it.
i highly suggest not using the drop pitman arm and trackbar bracket and just use an adjustable trackbar instead. The drop pitman arm can cause additional stress on the sector shaft/steering box
if you have a 2012 your also going to need to purchase the "exhaust extenstion"
Heres a few threads about this kit
https://www.jk-forum.com/forums/jk-s...talled-242729/
https://www.jk-forum.com/forums/modi...-3-5-a-241462/
https://www.jk-forum.com/forums/modi...5-lift-139537/
https://www.jk-forum.com/forums/modi...es-2-a-233992/
Name:	Jeep Mountain.jpg
ID:	353369   Click image for larger version
ID:	353371   Click image for larger version
ID:	353372   Click image for larger version
Old Aug 12, 2012 | 01:41 PM
Blakspire's Avatar
You would have to do some research on what you want. There are multiple sources such as J.E. Reel, Coast, Tom Woods, etc.
Search for those manufacturers in the forums and you will get reviews and such.
Old Aug 12, 2012 | 02:04 PM
saharaboy's Avatar
thankyou everyboby
Old Aug 12, 2012 | 02:08 PM
saharaboy's Avatar
CROCE- do i have to buy the adjustable track bar separate from the kit
