Tire pressure
Old Aug 13, 2012 | 06:03 AM
Zenabi's Avatar
Default Tire pressure
What tire pressure do you guys usually run in the trail grapplers 35's ??
Old Aug 13, 2012 | 06:05 AM
wayoflife's Avatar
JK-Forum Founder
for a 35, i would say about 30 psi
Old Aug 13, 2012 | 06:42 AM
rays0852's Avatar
For load range E and D tires on a JK or JKU you can run anywhere from 27-32 PSI on the street. The lower the PSI the better ride you will get in that range, but some people do a lot of HWY so they are more comfortable in the middle to high range. I run right about 30, but sometimes I will run 28 for a nice smushy ride.
You will probably need a PROCAL or tuner to set your TPMS threshold lower if you run 30 or lower.
Old Aug 13, 2012 | 06:49 AM
Noxian's Avatar
I run 30 in my 315/75R16 D rated Maxxis Bighorns. Seems to give pretty good wear, ride and fuel economy. Anything more and you can see noticeable wear in the center of the tire and a very bouncy ride.
Old Aug 13, 2012 | 07:38 AM
afpilot82's Avatar
JK-Forum Ambassador
Run a chalk test and you'll be able to dial in your psi. Search the site, plenty of info on how to do it.
Old Aug 13, 2012 | 07:50 AM
Zenabi's Avatar
Yea im still waiting to see if procal will work with my 12
Old Aug 13, 2012 | 09:19 AM
Nwapache's Avatar
It will...
Old Aug 13, 2012 | 11:48 AM
rays0852's Avatar
Originally Posted by Nwapache
It will...
X2...mine is a '12 and it works.
Old Aug 13, 2012 | 12:29 PM
aha's Avatar
aha
Procal worked perfect on my '12
I am running 32 PSI on my Load Range E 35" MT's. Its a bit bumpy but I do mostly highway driving and prefer the better gas mileage.
Old Aug 13, 2012 | 03:53 PM
Zenabi's Avatar
Why is the max pressure so high?
