RIM OPINION NEEDED!and bs help....
Old Jan 3, 2008 | 12:19 PM
The Joker's Avatar
Default RIM OPINION NEEDED!and bs help....
what do you guys think of this rim?
it's a 17x9 with +10 backspace
how does that compare to a 4.75 backspace? I don't understand the difference...
btw, I'm planning on 33/12.50x17 and eventually 35's will this work?
Old Jan 3, 2008 | 12:42 PM
CMac's Avatar
Go to the sticky at the top of this page for FAQ. It is explained very well. Good luck.
Old Jan 3, 2008 | 01:10 PM
The Joker's Avatar
right, I read it but i just don't understand backspacing very well, I don't understand the difference between what a 4.75 in inches is and a +10 backspace.
that is what i need explained.
Old Jan 3, 2008 | 03:25 PM
jkdwindeck's Avatar
Something sounds wrong there. Could ??? mean +1" (positive offset) ??? With the mounting surface in the center, offset is zero and with lets say a 10" wide wheel the backspace would be 5". Now you can have positive and negitive offset. This moves the mounting surface out or in towards the axle.
Old Jan 3, 2008 | 04:02 PM
Paul R's Avatar
The +10 sounds more like millimeters of offset, not backspacing. Some rim manufacturers list offset rather than backspace. The faq above explains the difference in these 2 measurements quite well.
Old Jan 3, 2008 | 04:09 PM
The Joker's Avatar
DOH!!! MY FAULT GUYS!
it is +10 OFFSET.
sorry, but it doesn't list a backspacing.....
here is the link to the same rim.
the ones they have in stock at my tire store are 17x9 +10 OFFSET
what about backspace??? after reading the FAQ i still don't get it....
so i guess my question is......
on a 17x9 rim, a +10 offset = fow much backspace?
I'm sorry i don't understand the FAQ, I just need some help.
