A Tru Newbie Question
Old Jan 3, 2008 | 01:00 PM
Green Recon's Avatar
Default A Tru Newbie Question
What is the difference between bias ply and radial? And what are the pros cons of each. Thanks to whomever for answering.
Old Jan 3, 2008 | 01:32 PM
The Joker's Avatar
The difference is in the way the body cords are put in the tire . A bias tire has the body cords (plies) on an an angle (bias) to each other. A radial tire has the body plies running parallel. The advantage of a radial tire is that it runs cooler, making it last longer. A bias tire does not "bulge" at the bottom so it is not as prone to be damaged as easly to curb scuffing.
Bias are mainly for offroad. Radial are for both but lean twards on road.
Old Jan 3, 2008 | 01:40 PM
Ronson's Avatar
I use the bias ply for my hunting jeep off road only works well . The steel plys in the radial tire only last a couple years in the desert heat so your buying new tires then you only have like 2000 miles on them.For anything you drive on the highway I would stick with Raidals
Old Jan 3, 2008 | 02:05 PM
if I run 70 percent off road and 30 percent on road could I get away with a bias ply? I ask only because I really like how I can get the super swamper LTB in 34" x 10.5". Thanks
Old Jan 3, 2008 | 04:22 PM
What do you mean by flat spots? Anyone know of a different 34" by 10.5" Tire?
Old Jan 3, 2008 | 06:11 PM
Ronson's Avatar
When the bias ply tire sits on the ground for awhile it will get a flat spot but it will roll out as soon as you get them warmed up . I have no experience with them in cold weather though.
Old Jan 4, 2008 | 06:25 AM
Sv650's Avatar
If it gets cold enough, radials do the same. Quite funny when you make the turn out of your driveway, and the flat spots are no longer synchronized!
