JK adj front LCA's length for 3" lift?
I'm currently running fixed length WP LCA's for my 3" lift. They do not utilize any flex joint ( johnny joint etc)just poly joints, and so put a lot of stress on the axle mount when flexing. I'm buying TeraFlex adj front lca's and need to know the adj length I run for 3" lift. 3/8 of an inch over stock for both sides? Also, I thought I heard something about the pass side being a tad longer? What length do I need to adj my front LCA's to? thanks for help
I've been told 23" center of eye to center of eye before, so would I possibly go a bit longer depending on how it feels bump steer wise? what would let me know I should go any longer? thanks for your input
I got a centered axle by adding 7/16" to the stock length. My lift is called "2.5" but I think it is more like 3" in front and 2" in back to eliminate excessive rake.
Edit: Oops, I thought the O.P. said track bar. I'll leave this reply here anyway in case the info is useful to someone.
I will start with 7/16" on track bar... and I was told to add 1/2" on control arms and then dial it in...
