Help installing Currie's rear coil spring retainer kit
Old Aug 18, 2012 | 01:44 PM
C2U5H's Avatar
Default Help installing Currie's rear coil spring retainer kit
I can't figure out how to get the top portion of Currie's rear coil spring retention kit installed ... it seems there's not enough space to slip the bung on the top of the coil spring bucket, let along get a wrench up there between the bucket and the body.
Jeep is a 2012 JKR. Got the lower portion of the kit installed no problem.
Any help out there??
This is the kit I speak of: http://www.currieenterprises.com/cestore/product.aspx?id=2852
Thanks!
Old Aug 18, 2012 | 07:26 PM
JK-Rubi's Avatar
Ha, I remember wondering the same thing but was able with much patience to get a wrench up on top (accessed through the rear fender well if I remember correctly). Have fun.
Old Aug 18, 2012 | 08:02 PM
Absolute's Avatar
There is room to do this, I've done it plenty of times. A closed end wrench would work best for the nut on top. It just takes time and patience.
Old Aug 18, 2012 | 08:05 PM
D_engel's Avatar
I made my own version of curries upper coil retainer and it was definitely tough getting the rubber plug and bolt through the top. Just like everyone else said, patience is key. And remove the rear wheels to give you more room to work
Old Aug 19, 2012 | 07:30 AM
DanieltheManual's Avatar
The actual piece doesn't fit, between coil frame and the body ..anyone do this on 2011 or newer? If so, the op needs to know how you got it in there ....
Old Aug 19, 2012 | 07:40 AM
D_engel's Avatar
you cant go through the fender well. You have to get under the jeep and slide them in from the inside edge of the bucket.
Old Aug 19, 2012 | 07:50 AM
To clear things up, those with this kit from currie, do you have a body lift or not....I can tell you mine wont fit either ....
Old Aug 19, 2012 | 08:10 AM
Absolute's Avatar
It could be newer JK's have this issue. Mine is an 09.
Old Aug 19, 2012 | 09:49 AM
D_engel's Avatar
mine is a 10. No body lift. Than again, the bungs I used could have been slightly smaller than those provided in curries kit
Old Aug 19, 2012 | 10:58 AM
JK-Rubi's Avatar
Sorry, mine is an '07. Sounds like a possible change to the coil bucket was incorporated into the newer JKs.
