JK Off-Road 101 Bulletin board forum regarding topics such as general off-roading tips, tricks, techniques and equipment usage such as winching and vehicle recovery information.
Sponsored by:
Sponsored by: CARiD
Short Arm lift suggestions?
Old Aug 30, 2012 | 03:49 PM
kuhn.blaine's Avatar
Default Short Arm lift suggestions?
I am currently running a standard 3.5" RE lift with Bilstein 5100 shocks on my '08 2dr. I am not too happy with the setup and am planning to try it again. My ride is VERY rough and the lift makes a TON of undesired noise. I half expected a loss in ride comfort but nothing to this degree...
Any thoughts on a high quality SMOOTH RIDING SA lift? What SA lift 3.5-4" is the most "bang for buck?" I do do a little off-roading, it is a jeep, but nothing too serious (rock crawling). Also, what shocks to go with lift? Plan to do a lot more to this jeep but want to straighten out ride and performance first and foremost.
Old Aug 30, 2012 | 07:12 PM
Mhare's Avatar
You can't go wrong with teraflex. Mine rides great and the customer service is awesome. I was discussing a rear track bar issue that I was having here on the forum. Then out of nowhere teraflex jumps in and said. We changed the design of that bracket. Let me send you a new one for free!
Old Aug 30, 2012 | 09:19 PM
lkjk's Avatar
I'll be going with the rock krawler 3.5" max travel kit shortly. just over $2gs for everything with shocks and I haven't read a bad thing yet.
Old Aug 31, 2012 | 08:20 AM
I really do admire Teraflex, just having a hard time finding their right lift for me. I was also looking at a Currie 4" and was wondering of anyone knows of someone running that??
Old Aug 31, 2012 | 09:01 AM
Tonka_yellow's Avatar
Like everyone is saying rock krawler then teraflex
Old Aug 31, 2012 | 11:30 PM
GJeep's Avatar
A Jeep can be made quite soft, but this would undermine offroad capability.
The relatively softer springs are Full Traction and OME.
Mine is Full Traction, 8 short arms and FOX shocks + reservoirs.
The ride is quite pleasant on roads and definitely softer then the stock suspension.
No noise from the suspension.
The Fox shocks could be re-valved to make the ride even softer, almost car-like, but then, offroad, the bump stops would have been frequently hit.
Tire pressure, at 28~30 psi, will, too, soften the ride.
Old Sep 1, 2012 | 05:32 PM
Thanks for the input. Think I am going with Rock Krawler mid-flex and fox reservoirs shortly after.
Old Sep 1, 2012 | 07:18 PM
BRUT4CE's Avatar
Former Member
Can't go wrong with either I am really impressed with my terra flex 8arms and fox shocks....
Always been a high speed desert guy and fabbed a lot of my trucks and suspension so its been a cool experience to be able to grab a bolt on quality set up....granted crawling is different then desert but the passion is the same....
Old Sep 1, 2012 | 09:01 PM
KSU_MAN_JK33's Avatar
OP: I am running the OME HD lift which netted me around 3" on my 2dr and their standard nitro shocks. I run the Teraflex Short Flex Arms to compliment it. The ride is great - comparable to stock ride. Just my two cents...
Old Sep 2, 2012 | 01:47 AM
wvudave's Avatar
I bought a zone 3in for my 08 for about 550 it was easy to install(bout 4 hrs) and i have no problems so far. The only thing that i bought extra was a dual steering stabalizer.but this is coming from a jeep newbie...
