Mud Terrains and /32
I was wondering at what point should the stock 32" MT's be replaced. Is there an amount, say 12/32's or 6/32's, left when it should be replaced? I can't see taking these down too low and expect them to work all that well.
Thanks
Thanks
Im sure it will vary greatly based on overall use but i've found that generally once the tires are down to about 7 or 8/32s there is a pretty big drop off in performance in bad on road weather as well as off road. of course mud will usually require even more tread then other terrain..... HTH
