anyone tried bigger oil filter?
Old Sep 21, 2012 | 06:17 AM
carolinajk's Avatar
Default anyone tried bigger oil filter?
a few years ago , i started using a motorcraft fl1a on my wifes minivan because i realized i could get right at a qt of extra capacity , i believe it will clear on our jeeps and gonna try it next oil change . it will. be close and will stick out furthur and would not be a good idea for rock krawlers but if it clears im gonna run it , anyone tried it ?
Old Sep 21, 2012 | 06:24 AM
ronjenx's Avatar
Yes, people have posted about using bigger oil filters.
Old Sep 22, 2012 | 03:14 AM
ezav8tr's Avatar
Vet Army
3.8 liter engine?
Old Sep 22, 2012 | 05:39 AM
CerOf's Avatar
I use a motorcraft fl400s I think is the part number. Bigger than stock. Works well and no engine tick.
Old Sep 22, 2012 | 05:51 AM
Firelyle's Avatar
I do as well....no issues.
Old Sep 22, 2012 | 06:16 AM
drumnatural's Avatar
What about potential issues with a lower oil pressure do to larger filter?
Old Sep 22, 2012 | 06:19 AM
Robar's Avatar
Here is a list of oil filters that work with the 3.8 engine:
----Make------Stock------Oversize
Amsoil--------EAO57------EAO34
Fram---------PH3614-----PH3600
K&N---------HP-1002-----HP-2009
Mobil--------M1-102------M1-209
Mopar--------L-335----------???
Napa----------1348---------1516
PureOne----PL10241----PL20195
Purolator----L10241------L20195
Wix------------51348-------51516
In my '07 JK, I've used the Fram, Mobile and Purolator filters at one time or another.
Old Sep 22, 2012 | 06:45 AM
rinkishJK's Avatar
Thank you Robar!
Old Sep 22, 2012 | 09:15 AM
JKosmos's Avatar
It won't be an issue just because of a larger filter. But you would want to add the appropriate amount of oil for how much bigger the filter is. Besides more filtration and less resistance, that's part of the idea...more capacity and therefore cooler running oil. Although your difference will probably be negligible as far as temperature.
Old Sep 22, 2012 | 09:19 AM
carolinajk's Avatar
thats why i ran the bigger filter on her van , the motorcraft held almost an extra qt and it eliminated cold start tick i should have done a search tho because this topic was already on here . there will be no pressure issues just fill to the full mark as you normally do
