Hybrid lift
I am trying to make a 'hybrid 4" lift' with components from different manufacturers to try and save some money.
This is what I came up with:
Rusty's Offroad:
Front Adjustable Control Arm system
Rear Upper CA's (adjustable)
Rear Lower CA's (adjustable)
Front & Rear Sway bar Links
Rear Adjustable Track bar
Teraflex:
Bumpstops
Offroad Evolution
Plush Ride Coils - 4"
Drag Link Flip Kit
Roll Center Rear Track Bar bracket
Miscellaneous:
Bilstein Shocks - 5100's (for 4-5" lift)
Extended Brake Lines
All of the above totals up to $2600 on the button.
What do you guys think of this hybrid lift and these components??
Anything else I "need"?
Any other recommendations for parts from other places??
Rusty's Offroad:
Teraflex:
Bumpstops
Offroad Evolution
Drag Link Flip Kit
Miscellaneous:
Rusty's Offroad:
Teraflex:
Bumpstops
Offroad Evolution
Drag Link Flip Kit
Miscellaneous:
Rusty's Offroad:
Teraflex:
Bumpstops
Offroad Evolution
Drag Link Flip Kit
Miscellaneous:
I have looked into it a million times...my only thing with it is it doesn't have adjustable CA's across the board. It only has front lower CA's...
From wayalife:
Q: What are all the components that I will need with a 4" lift?
A: For a 4" lift, you should have a set of 4" coils, bump stop extensions, longer shocks, extended brake lines, longer sway bar links, adjustable front track bar, adjustable rear track bar, front and rear track bar relocation brackets, dropped pitman arm, adjustable upper and lower control arms front and rear and new double cardin u-joint style drive shafts.
On a 2012-Up, you will want to install a new front drive shaft regardless if you have an automatic or manual transmission. Assuming you install new, longer shocks with your lift, the extra droop you will see at a flex will cause the slip shaft boot on the drive shaft to tear. However, that is just one problem you will encounter. Even if you install exhaust spacers or relocate the cross over, the CV boot at the output shaft will be sitting at a significant state of pinch and this will cause it to fail prematurely.
Rusty's Offroad:
Teraflex:
Bumpstops
Offroad Evolution
Drag Link Flip Kit
Miscellaneous:
Rusty's Offroad:
Teraflex:
Bumpstops
Offroad Evolution
Drag Link Flip Kit
Miscellaneous:
