Proper way to measure rake
Hi all. What is the most exact way to measure the JK rake? I would like to get the teraflex leveling kit (2" in front and 1" in rear) and I'm concerned that I'll end up with a reverse rake.
I have a 2010 Mountain and the front is only 0.75" lower than rear. But maybe I'm not measuring right?? Thanks.
I just measure to the lip of the fender holding the tape so it drops along the center of the wheel.
If your front is only .75" lower, then I doubt you would notice a .25" increase over the rear.
However as was said, if you do load up heavy, your rear can sag badly.
You can also look at getting 19/60 springs and seeing how you like that. You can get then from your dealer for $130. Or just buy the rear springs and the leveling kit to get the lift and rake eliminated.
Although not scientific, the way your doors swing open is indicative of your rake (so long as you're on level ground).
