Front drive shaft
Old Sep 25, 2012 | 07:41 AM
Nkrimmel2012's Avatar
Default Front drive shaft
Just wondering if a 2012 drive shaft would bolt up to a 2007.. and comments, or concerns are helpful.. Thanks in Advance...
Old Sep 25, 2012 | 08:11 AM
And no problems.. bolted right up? Did he replace the yokes too? Or just the DS
Was there anything he had to do.. or did he just silicone it and locktite the bolts?
Old Sep 25, 2012 | 10:42 AM
Also does he have a lift and a set caster angle?
Old Sep 25, 2012 | 11:31 AM
So just locktite on the 12 bolts and your done?
Old Sep 25, 2012 | 02:47 PM
stevedolce's Avatar
I have a 11 and swapped the DS with something earlier. Dropped the shaft out and kept the yokes in. 12 bolts and good to go. You may wanna get a small 1/4" socket to get in close to the bolts. It's an hours or 2 at most. Not hard at all
Old Sep 25, 2012 | 04:31 PM
river2c's Avatar
The drive shafts for the 2012-2013 JKs are different lengths than the 2007-2011 because of the different drivetrain (engine and transmission). I'm not saying they aren't interchangeable, but I'd double check the lengths and clearances to be sure.
Old Sep 25, 2012 | 05:47 PM
Will do.. thanks for the heads up
Old Sep 27, 2012 | 07:42 AM
Do y'all have any insight of where the caster should be so I don't tear this new one up?
Old Sep 27, 2012 | 08:22 AM
So if I'm not really knowledgeable about how it should be.. how should I go about doing it?
