catalytics clogged or high altitude?
Old Sep 26, 2012 | 09:36 PM
DocFuller's Avatar
Default catalytics clogged or high altitude?
Just moved to Colorado Springs from D.C. and noticed a little more sluggishness than normal. I have a CAI only, and running 91 octane to see if that helps. Banged on both cats under '07 Unlimited X, heard a little bit of 'junk' in there. I know fuel injection/computer is supposed to automatically adjust ( new plugs and oil change recently ), but maybe altitude still affects stuff? Not talking steep-graded hills, either... 58,000 miles- manual trans.
Old Sep 27, 2012 | 04:48 AM
JKLarson's Avatar
I'm guessing altitude...a lot less oxygen at 6,000 feet than at sea level...welcome to Colorado!
Old Sep 27, 2012 | 04:55 AM
ronjenx's Avatar
Higher altitude = less air into the cylinders = less fuel injected = less power.
It also means you can use lower octane gasoline because the higher altitude is similar to lowering the compression ratio.
Old Sep 27, 2012 | 05:13 AM
Ludo's Avatar
I moved Colorado Springs to Houston in july. my jeep was sluggish up there also. Mine had a hard time with climbing long hills, i would have to downshift to 4th to make it up the hill at Powers BLVD and Barnes heading north. It felt like i had a 4-cyl. Once i moved to Houston i noticed better throttle response, more power, and a deeper tone in the exhaust. so I am thinking high altitude but i have had the dealership change my o2 sensors 3 times due to it stalling while at a red light.
mine-
3.5 in lift
35" duratracs
4.56 gears
manual tranny
38,000 mi.
oh by the way if your in the military check out Military jeepers of colorado springs.Colorado Springs
Old Sep 27, 2012 | 05:14 AM
JKLarson's Avatar
HP Loss = (elevation x 0.03 x horsepower @ sea level)/1000
For Colorado Springs (approx. elevation 6000 feet), I'm assuming you have a 2011 or earlier with 58,000 miles on it = 202 HP for the 3.8 L:
(6000 x 0.03 x 202hp)/1000 = 36hp loss
Now you are running around 166 HP...
I have a 2012 with the 3.6 and live in Denver:
(5500 (average el.) X 0.03 X 285hp)/100 = 47hp loss
Now I'm running around 238hp...
Old Sep 27, 2012 | 05:25 AM
ronjenx's Avatar
My first car had only 36 hp to start with.
Thanks for the formula.
Old Sep 27, 2012 | 07:13 AM
Rob50lx's Avatar
Don't forget about the DA (density altitude) of our air. Living in the Springs usually has a DA of 8,000ft +. So our air quality in regards to performance sucks. Also if you came from a place that had straight gas without ethanol; you are taking another performance/mileage hit.
When I moved here from Florida 6 years ago; I was shocked how much the gas and altitude killed the performance in my 2 Jeeps and Mustang. I brought several Jerry cans full of good 93 octane Florida gas. When the gas ran out, I noticed a 2mpg decrease in the Jeeps besides the 1mpg decrease from the altitude. The Mustang took such a performance hit that I made significant changes to the engine to regain the lost performance.
I was never a fan of forced induction until I moved here. I didn't like the added heat, complexity, or weight to the nose of the car. Now I am considering adding a blower to my JK and Mustang.
Rob
Old Sep 27, 2012 | 07:38 AM
DocFuller's Avatar
[QUOTE="JKLarson"]
Holy loss of testicles, Batman!
Old Sep 27, 2012 | 07:41 AM
DocFuller's Avatar
So I'm just wasting money running 91 octane with Superchip? And will dyno-ing her bring her back to 'normal' power production??? I'm gonna be here a few years, so the cost may be worth it...
Old Sep 27, 2012 | 07:59 AM
Ryan0260's Avatar
Volkswagen?
