slight wobble/shimmy between 50 &60 mph
I have a very slight wobble between 50 & 60 mph. it does not matter if road is smooth or rough. I have checked the whole front end and everything looks great. Nothing loose or worn out.
Tires were balanced a month ago, set at 30psi, tires have 6k on them, steering stabilizer has about 15k on it looks good no leaks or signs of wear. It does seam like the wobble started after a tire rotation and balance.
Trail Grappler
Any time I hear shimmy between speeds its almost 9/10 times going to be PSI or balancing issues. 30 psi might be a bit low for your setup, Nitto recommends up to 65 psi for the trail grapplers @ 35", your only rocking half that.
Trail Grappler
Trail Grappler
