33" on stock carrier
Old Oct 3, 2012 | 07:26 PM
2012 Sahara's Avatar
Default 33" on stock carrier
Can I carry a 33" tire on a stock 18" Sahara rim on my stock spare tire carrier?
Old Oct 3, 2012 | 07:32 PM
k0260's Avatar
yes definately. No problem. You may need a spacer depending on how wide of a tire you get. From the weight, you may notice occassional 'clunk' from the tail gate moving up and down slightly.
Old Oct 3, 2012 | 07:40 PM
MarbleheadGuy's Avatar
From someone who ran a supremely heavy 35" Toyo MT with weighty steel wheel on the stock carrier for over a year with no problems...yes, you'll be fine!
Old Oct 3, 2012 | 07:43 PM
newtdog's Avatar
Yes you can!!
Old Oct 3, 2012 | 07:48 PM
woodyvw9's Avatar
Veteran: Coast Guard
I carry a 33" Nitto Trail Grappler on a stock Moab wheel with out issue.
If you don't use a spacer or trim the rubber bump stops or really force the tire against then to get the lug nuts on.
Old Oct 3, 2012 | 09:33 PM
thanks guys, duratracs..here I come....
Old Oct 4, 2012 | 01:33 AM
Kojack's Avatar
Day star makes a nice bump stop replacement for the spare tire. Good solid units, easy to trim.
Old Oct 4, 2012 | 06:37 AM
Boyerracing343's Avatar
I have a 35x12.5x15 on my stock tire carrier at the moment, until I upgrade. The 3.75 backspacing my wheels have helped it fit nicely. Third brake light is still completely visible
