16" x 7" rim...how big of tire is too big?
As stated, I have a 16x7 2007 rim on my sahara unlimited. I know that there is a thread that has stock wheels with 35" tires but no one really addresses this smaller (thinner?) rim. I would love to get 315s or 35s and I was told by a tire shop that they will mount it. The problem will be that it will not wear correctly and my handling or drivability will not be that great. I see that tire manufacturers state rim size ranges and everything between 33 (285) to 35 (315) state that an 8" rim or greater is recommended. Can someone please advise from a knowledge and experience background. I don't want to replace any new tires sooner than I would normally need to. Thanks in advance.
Originally Posted by Hmcostapro91
I had 285s on stock 16s for awhile and they rode fine. I have 315s now but I have aftermarket 16s instead cause u couldn't stand those stock rims
I run 35x12.50's on the stock Sahara wheels which are 7.5" wide with no problems. The main thing you need to do is make sure and do a chalk test and get the air pressure right so the tire has a flat contact patch with the road
Don't risk your life, your passengers life's and every one else on the road cause you want to run a setup that's unsafe. Those tires are too big for those wheels and that shop should know better. Why not run some cheap 15x8.5's?
