Using wheel spacers with aftermarket wheels
Old Oct 7, 2012 | 05:21 PM
jksearles's Avatar
Default Using wheel spacers with aftermarket wheels
Is it ok to use wheel spacers with aftermarket wheels that have 4.5 back spacing. Just trying to get a wider stance
Old Oct 7, 2012 | 05:24 PM
swaite3's Avatar
It's going to put a lot of leverage on the axles, how wide are the rims?
Old Oct 7, 2012 | 05:25 PM
Opalgem's Avatar
If your using wheel spacers which I don't recommend then at least get some longer wheel studs so there are enough threads engaged to hold the tire on properly.
Old Oct 7, 2012 | 05:31 PM
swaite3's Avatar
I think he is talking about bolt on spacers hub centric or at least I hope he is
Old Oct 7, 2012 | 05:49 PM
Freewill's Avatar
All the aftermarket wheels I've looked at already have more backspacing than a 1.5" spacer, so what would be the point?
Apart from looks and rim width, the good thing about aftermarket wheels is you can pick one with the backspacing you need so that spacers aren't needed.
Old Oct 7, 2012 | 05:56 PM
Tkautos@verizon.net's Avatar
I don't mean to hijack your thread, however I am looking at wheels that only come with 3.5" backspacing. If I add 1.25" wheel spacers would that put the backspacing at 4.75" or is that not how it works?
Old Oct 7, 2012 | 06:02 PM
jksearles's Avatar
Yes I'm talking about hub centric and the only thing I'm trying to do is a wider stance. The 12.50's I have now with 4.5 backspaced wheels put the edge of the tire even with the fender. I'd like to have them out a little further than the fenders
Old Oct 7, 2012 | 06:07 PM
swaite3's Avatar
I think you would be ok with 1.25 - 1.5 spacers with that setup. You will however chew up the paint on your doors and rear fender with the tires sticking out that far
Old Oct 7, 2012 | 06:08 PM
BarRegular's Avatar
You sure they're 12.5? My backspacing is the same, running 35x12.5 and my tires stick out an inch
Old Oct 7, 2012 | 06:37 PM
1978cj7jk2012's Avatar
Mine stick out about 1.5 inches with 33/12.5s with 16x9 wheels with 4.5 inches if backspacing...
