control arms on 2.5 lift
Old Oct 10, 2012 | 07:33 PM
hogwild's Avatar
Default control arms on 2.5 lift
How many people have had to use uca's or lca's after your 2.5 or so lift to correct any camber problems and any problems in general? Should I just put them on regardless????
Old Oct 10, 2012 | 07:39 PM
brutalvette's Avatar
I have had my 2.5" lift on for over six months and I don't think it is necessary. I did not notice much of a change in flighty ness.
Old Oct 10, 2012 | 07:41 PM
k0260's Avatar
You won't need lca's or uca's until you go up to 3" +. Unless you want smoother flex with arms that utilize a Johnny/flex joint. I started off with 2.5, didn't need anything but the coils and shocks. Went up to 3" and needed a whole lot of other goodies to regain ride quality and performance.
Old Oct 10, 2012 | 09:02 PM
Freewill's Avatar
Think you mean castor. The higher the suspension goes the more it changes, so for sure it will be different at 2.5". It makes the steering feel flighty or twitchy. Some drivers hate it, others don't mind until it gets hard to control.
I don't think you can go wrong by using suspension components that keep the Jeep handling at its best.
Old Oct 10, 2012 | 09:11 PM
courtsm3's Avatar
agreed. its up to you, i have no complaints with my 2.5 JKS lift but its your ride. i might tweak mine a bit to make it drive " tighter ". but as of right now, I'm not changing anything
Old Feb 11, 2013 | 09:23 AM
joey0480's Avatar
interesting thread. I am running into quite a bit of flightyness on a 2.5 inch lift now.
Old Feb 11, 2013 | 09:35 AM
Smashboogie 4x4's Avatar
Former Vendor
We always recommend installing at a minimum adjustable front lower control arms. Not only do these arms correct the castor issues but they are also much stronger than the factory arms.
At 2.5" of lift the castor is off but its not terrible. You will lose some of the factory drivability and have some "flighty" steering (some people may not notice it). Pretty much any suspension lift will change the geometry its just a matter of how receptive the driver is to that change.
Let us know if we can help at all.
