What tire pressure are you running in your 35s
Old Oct 11, 2012 | 08:34 PM
skibovr6's Avatar
Default What tire pressure are you running in your 35s
I was curious after reading another thread what tire pressure are you guys running on 35s? I am running 35x12.50x17 MTR/K. I am currently at 30psi. Just wanted to know. I did some searches and saw the 33 crowd step up but not so much 35s. Thanks for the info
Old Oct 11, 2012 | 08:39 PM
TheTerminator's Avatar
I had 32 psi, then 28 psi. Don't think I noticed any difference.
Old Oct 11, 2012 | 08:41 PM
afpilot82's Avatar
JK-Forum Ambassador
I run my MTR/Ks at 29 psi. Gives me a good ride, even contact.
Old Oct 11, 2012 | 09:10 PM
Bob Thario's Avatar
Per the math, I should be running 26 psi. However, I run 30psi. I run 35psi when I tow my trailer and definitely notice a difference in ride quality.
Old Oct 12, 2012 | 01:06 AM
GJeep's Avatar
Same size tires, usually 30 psi.
Chalk test showed that the tread sits flat at this pressure.
For long distance at summer in the desert -- about 28 psi. The tires get quite hot so pressure increases.
Old Oct 12, 2012 | 02:53 AM
16 Unlimited Ways's Avatar
Im running also 30 PSI...Everything good here...
Old Oct 12, 2012 | 03:08 AM
Kojack's Avatar
I run 30psi in my tire as anything higher makes the jeep handle like shat
Old Oct 12, 2012 | 04:26 AM
robinson86's Avatar
Originally Posted by gamesveta
250lbs running 25mm Vittoria Rubino Pros (that I hate, by the way) at 110 front/120 rear. No pinch flats, but have had several flats on them. Most frequently in the wet. In contrast, only suffered one flat on previous Maxxis Re-fuses, before they wore out, and that was due to riding through a construction site.
I suspect that those rated pressures that Beanz found are a mis-print. I find it hard to believe they (Vittoria) would rate their 25's to the same pressure as their 23's. I know that in the Rubino Pro's you certainly loose ten psi or so when you go to the larger tire. I would trust the sidewall more than a web page.
fake doctors note
This is the Jeep JK forum not your bicycle forum. You probably should have had your first cup of coffee before using this as your first post to the JK Forum.
Old Oct 12, 2012 | 04:45 AM
Ryan0260's Avatar
Do a chalk test, and lower the pressure until you get a flat contact patch with the road
Old Oct 12, 2012 | 05:22 AM
backcountryislife's Avatar
I really need to give that try... I run my Guard dogs (35's) at notably higher than most are posting, and wonder where I should be. My tires are rated at 50psi, and on road I run them at 40-45. I'll admit that my Jeep feels like it has serious toe in, despite being aligned, so maybe dropping to 30ish would help that a bit!
