Painting vs powdercoating
Old Oct 13, 2012 | 06:15 AM
Flexwell's Avatar
Default Painting vs powdercoating
I just ordered a set of PSC rocker knockers for my 13' JKU. I wasn't sure if it would be better to have them powder coated or if a regular poly would hold up fine. Powder coating is a little pricey where as I can have the paint done free.
Old Oct 13, 2012 | 06:17 AM
golfer97's Avatar
Most people I know with the PSC just rattlecan them with a bedliner. Either rustoleum or duplicolor. It's cheap, looks great and blends in well when you need to touch them up. If you are driving your jeep properly, you will need to touch them up a lot!
Old Oct 13, 2012 | 06:21 AM
Nibsirb's Avatar
i agree w/ the spray on bedliner option. atleast that way you can touch up whenever you need...def. the route i would/will be taking (eventually)
Old Oct 13, 2012 | 09:18 AM
snytribe's Avatar
I rattle can sprayed mine with primer and bedliner. Sprayed the inserts with a metallic paint and they have held help great. In another post someone suggested using rocker guard paint for looks with the same texture. If I were to do mine again I would try that.
Old Oct 13, 2012 | 01:04 PM
skibovr6's Avatar
i am a lover of powdercoat for bumpers and other parts that normally rust. on any part that can easily get scratched get something you can repair like bedliner
Old Oct 13, 2012 | 01:59 PM
DSOY's Avatar
I would go with the bedliner. Easy to blend.
Old Oct 13, 2012 | 02:01 PM
CherrySaharaJk8's Avatar
Powder coating would be my choice. Had a set of wheels powder coated a long time ago and nothing has fazed them.
Old Oct 13, 2012 | 02:04 PM
Flexwell's Avatar
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=377678"/>
I like the way those came out. They look rugged yet clean at the same time..
Old Oct 13, 2012 | 03:18 PM
ttechris's Avatar
Having recently used mine as rock sliders(saved my body panels) I would recommend using something you can easily touch up yourself. I used raptor liner on mine, but if I were to do it again I would go with something cheaper that's available at any hardware store.
Old Oct 13, 2012 | 05:39 PM
19Delta's Avatar
What rock rails are those? ^^^
