Rear sway bar disconnects?
Old Oct 14, 2012 | 06:17 AM
Devil Dog JK's Avatar
Default Rear sway bar disconnects?
Okay, I've built up my 2011 JKU pretty well over the last year and a half. I was a gear head growing up, but work as a civil servant now and really enjoy the time working on my Jeep. I'm not a mechanic by trade but I rebuilt engines, swapped rears, etc in my youth. But, I don't work as a mechanic, so please bear with me if this question is stupid. Do I need to worry about rear flex and articulation with the stock sway bar links. I have a RC 2.5 inch lift I installed myself and I also installed quick disconnects on the front and I get great flex on the front. I havent seen anyone really talk about rear flex a lot and as my mind wonders and I think about what to do add to my Jeep next I began thinking about rear flex. The stock rear sway bar links look pretty long, but would I benefit from adding disconnects to them? Does anyone make rear sway bar disconnects or would I just use the same ones as the front? Any thoughts or experience anyone has on this issue would be great. Thanks.
Old Oct 14, 2012 | 06:26 AM
rcdude3's Avatar
You wouldnt benefit. The stock rear swaybar is super soft already and will not limit any wheel travel.
Old Oct 14, 2012 | 06:27 AM
fishtale's Avatar
Keep in mind what the sway bar actually does not you for offroad stability. Think about the design of anti-rock sway bars and they stay connected. If you are fully disconnected up front I would advise not fully disconnecting in the rear.
Sent from my DROID RAZR MAXX using Tapatalk 2
Old Oct 14, 2012 | 09:42 AM
TheTerminator's Avatar
There is plenty of flex in the rear with sway bar connected. I don't think you'll gain anything if you disconnect.
Old Oct 15, 2012 | 01:01 PM
Thanks for all the feedback guys. Looks like my stock ones are plenty so I will stick with them and save my funds for something else.
