esp light and rubbing sound/feeling on turns
In late June I put a 2.5 inch lift on my 08 Jk. Now I have a rubbing noise in the drivers side when turning right. Figured it could be my Jeep thinking I was going too fast, but it happens randomly. The ESP light only turns on when I'm on the gas pedal while turning. But the rubbing noise still happens when I'm coasting. It just doesn't turn on the light. I don't know what this could be! Thought it could be a wheel bearing. But there is no side to side/ up and down movement on the tires. Help!!!!!
Adjust the drag link to recenter your steering wheel and whala! no more noise
[QUOTE=njfirefighter92;3256204]In late June I put a 2.5 inch lift on my 08 Jk. Now I have a rubbing noise in the drivers side when turning right. Figured it could be my Jeep thinking I was going too fast, but it happens randomly. The ESP light only turns on when I'm on the gas pedal while turning. But the rubbing noise still happens when I'm coasting. It just doesn't turn on the light. I don't know what this could be! Thought it could be a wheel bearing. But there is no side to side/ up and down movement on the tires. Help!!!!
