Easiest paint for wheel wells?
Old Oct 20, 2012 | 11:24 AM
CodyB4C's Avatar
Default Easiest paint for wheel wells?
What paint is everyone using for their wheel wells? I used undercoating on my last jeep and it didn't turn out very well...
Any good paint to use that takes very little prep work and will last a long time?
Old Oct 20, 2012 | 11:29 AM
Nibsirb's Avatar
i used Plasti Dip on mine. So far so good! Painted them probably around a month or so ago
Old Oct 20, 2012 | 11:35 AM
Murder¹'s Avatar
Beeline it just scuff the paint up a little clean it with some alcohol & then paint
Old Oct 20, 2012 | 12:36 PM
CodyB4C's Avatar
What did you use to scuff up the paint?
Old Oct 20, 2012 | 03:08 PM
Murder¹'s Avatar
I haven't done it my jeeps black but all you should need is some fine grit wet dry sand paper
Old Oct 20, 2012 | 08:34 PM
green pup79's Avatar
I used 80grit sandpaper and undercoat, I know you said you used that last time, but mine turned out fine.
Old Oct 20, 2012 | 09:49 PM
lkjk's Avatar
krylon fusion...haven't used it on the JK yet but it is just wipe and spray and holds up very well unless you are hitting it on stuff in which case nothing will last. thats what I will use on mine once i need to, i used it on my nissan a lot and it works great.
Old Oct 21, 2012 | 03:33 AM
JLsJK's Avatar
I tried the valspar satin black on mine and it worked out great. A little scuff scuff, wipe, and sprayed light coats. 4.98 at lowes.. Takes less than one can
Old Oct 21, 2012 | 05:38 AM
3gracing9's Avatar
I worked at a detail shop back in the day.. we used cheap black spray paint.. It works fine if you stay on top of it.
Old Oct 21, 2012 | 07:14 AM
JK yeti's Avatar
I used vht frame and chasis paint it works great just clean the surface good before you paint it on so it sticks better. It wont flake, or chip
