15" rim on a 2013 sport
Old Oct 20, 2012 | 05:56 PM
slidnby's Avatar
Default 15" rim on a 2013 sport
I have a set of 15*10 rims laying around the bolt pattern is the same 5*127. Has or does anyone run a 15 inch rim on these jeeps? Will they clear the brakes? If anyone has or is running 15 inch rims or knows if u can please respond thank you
Old Oct 20, 2012 | 05:58 PM
Robar's Avatar
Some do and some don't. If you have them lying around slip them on and see if they fit.
Old Oct 20, 2012 | 06:05 PM
slidnby's Avatar
Thanks ill try them when I get back heading to Kermit,tx in the morning
Old Oct 20, 2012 | 06:23 PM
mattgt5's Avatar
Johnnyquik has some on his 13 jk with 35s. They are pro comps. Send him a note for details.
Old Oct 20, 2012 | 07:33 PM
Wandell's Avatar
Loved
Seems like most steel 15's will fit but a few aluminum 15's won't.
Old Oct 20, 2012 | 08:21 PM
green pup79's Avatar
Correct. Cause alloy wheels have to be thicker than steel wheels are. I run 15in steel wheels, I have the procomps
