Rock rail / step bar
i bet theres many opinions on this. i ran rockhard skids on my last jeep. they are boat type with a 4 in wide top plate. very durable. they bolt to the body mounts and by bolting to the tub/body. some people do not like drilling the body on the're new jeep,but i ran em hard and would get them again
depends on what you do with them...if your hard on it then weld on is the only way to go...i have seen even the best bolt ons do major body damage when beat on hard enough,if not and you are mostly looking for a step then most will be fine although smitty is the bottom of the barrel in terms of quality in my book...
Originally Posted by jeeperaf
I run Ace Engineering. Fit wasn't 100% perfect (about 95%), but very happy with rails (2010 Rubi Unlimited).
LOD are both frame mounted and provide a flat stepping area. They take the most abuse you can give them, look great and serve a purpose above and beyond protection since they double as a step. Plus, they have been on Jk's longer than most sliders with very few complaints.
