Questions on ARB Twin Air Compressor
Im a noob to the off road scene and I have a several questions related to the ARB Lockers and etc.
Is the ARB Twin air compressor more than enough to handle both rear and front axle lockers, inflating tires, and using air tools with 1 gallon air tank?
Whats the purpose of an air locker manifold for the ARB twin air compressor?
Thanks
Thanks
Yes, that compressor is more than enough. The manifold just makes it easier to set everything up. You can buy another brand manifold if you want. You could even plumb the locker sylanoids inline if you wanted to or even mount them on a tank. I'm running the twin pump, arb manifold (I really don't recommend this manifold-I would get one of the straight aluminum block manifolds if I had to do it again), and a 2 gallon Viair tank with front and rear arb lockers. LOVE IT.
Where can I go to find an manifold that's compatible to the twin air compressor?
Would I need an air regulator and some type of safety valve for the air tank?
