rough country 3.5 lift issue
Hi i just installed the series 2 kit on my 2011 jk 4 door and the pitman arm does not fully ingauge the spines is this a common issue. thanx for any help
post up a pic and ill look and see if its about the same as mine. i cant remember mine looking like they had that issue but i could have just over looked it
if it is a common issue then the pitch on the arm must be off so ill off all the paint try again tanx rough country said they would warranty the arm but its such a hassle. and the drop bracket for thetrack bar wasnt in my kit they said its supposed to be there so they r sending it to me. Thnx for info.
Party Foul on us! Let me know if you need anything else!
Well the story doesnt stop there I also in my lift didnt get the front trac bar drop bracket and i was talking to someone in customers relations and you guys where great the bracket was sent out but it was the rear oops so i emailed back and asked for both to be sent out, as in the bracket and hardware and the pitman arm to me then ill return both at the same time im not upset about this but i do want the kit to be right. is this a common problem with the pitman arm?.
