Dynatrac 60 EPS, ABS Lights on
Old Oct 23, 2012 | 08:53 PM
trufffster's Avatar
Default Dynatrac 60 EPS, ABS Lights on
I recently purchased a 2007 Jk with Dynatrac prorock 60 front end (stub hubs).. all the lights in the jeep were working (basically all off) and my cruise control was also working perfect.... i brought my jeep to a friend to change the messed up rotor n caliper, and now the EPS BA, EPS, and ABS lights are all on and the cruise control doesn't work... Is this normal? a quick fix?.....and now there is a clicking sound coming from the passenger side, could he have installed the hub wrong??? would that not be simple? ALSO, i have a PCS hydraulic steering and i'm unfamiliar with how to tighten the front end so there is NO play in the wheel.....
I apologize if they are stupid questions, i've been out of offroading for around 7 years, and I wanted to get back into it, i'm only familiar with tj's and i never ran hydraulic steering and never had hubs.... any help would be greatly appreciated.... once i have all my evo gear ordered n installed i'll post pics!!! DISCOUNTS from EVO for forum members???? LOL cheers all!
Old Oct 24, 2012 | 04:57 AM
kage kicker's Avatar
As far as the lights go, I'd first check the steering wheel to make sure it is centered. If centered, I'd move to the wheel speed sensor connections to ensure they are properly connected.
Old Oct 24, 2012 | 06:26 AM
Dynatrac's Avatar
Sponsoring Manufacturer
Please call me. I'd like to find out more of what you've done. We should be able to get your issue figured out.
Scott
425-917-2361
Old Oct 24, 2012 | 06:11 PM
trufffster's Avatar
Ok I'll call tomoro... I think I found out my steerung problem, my buddy took it out and smashed in the hydraulic stabilizer... Was going to get a skid for it, but Ild like to find a proper conversion to place it 'above' the tie rod. I'll be callin dynatrac tomoro, hopefully figure something out.... Also not sure what he did but there is a 'clicking' sound when driving comin from passenger side hub or axle... Needless to say IM NOT PLEASED!
Old Nov 7, 2012 | 06:38 AM
quaylefarmer's Avatar
Should have followed through on your original plan and bought a better Jeep.
