EVO Rocker Skins and Rock Rails Questions
My next improvement is definitely protecting the oil pan. Of course the EVO skid like it is made very well and it is made here in CA so I'll be going with their skid.
Right after that I think it is rock rails. I really like EVO. I have a welding machine, but I am not a professional welder. I welded in my sleeves and LCA skids and I am very happy with the results. Anything particularly challenging with welding on the EVO skids? Is there clear directions on where to position them? Any lessons to pass on from those that have them or installed them?
Are rocker skins necessary for light work in the rocks? Will the EVO rails flex up and hit the body?
Thank you,
Brent
Thank you,
Brent
Thank you,
Brent
Thank you,
Brent
The sliders have 3 mounting points, directly to the frame. I haven't gotten them (yet), but from what I understand, most of the work is in prep, otherwise pretty straight forward.
No, they will not bend.
If you look on YouTube you will find tons of videos of WOL, GCM, and mel from evo beating the crap out of their evo rock rails.
I think rock skins are personal preference...do you plan on smacking your back end in to something the bumper can't protect?
Originally Posted by FlameRedJK
Everything evo makes is pretty bomb proof.
There's plenty of guys on here that only have the rails and not the skins. It's more for secondary protection incase something pokes through the rails. I got the poison spyder ones because they came bare and I'm cheap. The rails aren't going anywhere once they are welded on. I'm not sure how you would go about installing skins after rails though. So I would do the skins first if at all.
Thank you,
Brent
Thank you,
Brent
Originally Posted by JE8154
I'm pretty sure he meant the side armor rock skins not the rear corners.
The only thing I can add to the already accurate posts above, if you have the cash, get the rock skins too for the extra protection and because they look badass!
3 options:
- Install the rock skins at the same time as the sliders
- do the skins first and then save more cash and get the sliders later.
- install the skins after the sliders are welded on (least preferred)
I talked with the guys in the shop at Off Road Evolution and it is possible to fit the skins on after you weld up your sliders, but it can be a pain. You may even need to unbolt the body from the frame and lift the body up a bit to get some separation between the slider (which is now a part of the frame, and that's a great thing) which will help when installing the rivnuts/nutserts. Here are a few photos of my rig to help you make your decision
3 options:
3 options:
3 options:
That rig looks sweet!
