Is a new track bar worth it?
Hi guys,
So turns out the bolt on my track bar was a bit loose and has had some play in it for awhile, the bushing is probably a little degraded and could use replacing.
Question is, I have a 2.5" BB with 33" tires. Would I get any benefit in getting an aftermarket track bar? or should I just go with an OEM. If I am replacing something I would like it to be better instead of equal but wondering if I get any other plus besides added strength of the bar itself.
Originally Posted by Vladimer
Hi guys,
of course check the bushing for damage.
Anyone else know if investing in an aftermarket track bar has any benefit for my setup if I were to get one?
Thanks Chris, I'lll probably do that for the time being.
If you can spare the money, buy the Rough Country one since it's all you need and only costs $110 shipped to your door. Also get Grade 8 bolts to put in it. The stock bolts are bad for your Jeep.
Here's a couple examples of the stock bolts eating my trackbar bushings and giving me Death Wobble.
I ordered an adjustable track bar with my 2.5" Rubicon Express lift because the salesman said I needed it to center the axle for alignment. It wasn't in my shipment, a whole other story, and so I installed the lift and 35's without it. I can't visibly see any offset in the axle, the steering wheel is perfectly centered still, and I can't notice anything while driving it. I'll probably put on the adjustable track bar at some point when it arrives, but as of now I see no functional need for it. Stronger components is always a plus, but at 2.5" of lift it seems like a toss-up.
Thanks for all the suggestions guys. I was looking at the RC track bar and can't seem to get a solid answer on if it's a good buy or not. There is a lot of talk about the BDS track bar using a TRE mount which basically means it sucks? And the RC apparently uses the same mount on the end?
I unfortunately don't exactly know why that is a bad thing as all the posts I found regarding it simply just say its bad.
I offroad it a couple times a month at most and its nothing 'crazy', I'm more interested in overlanding. I just don't want to be replacing bushings in 8 months because it wore out just from normal use.
I unfortunately don't exactly know why that is a bad thing as all the posts I found regarding it simply just say its bad. I offroad it a couple times a month at most and its nothing 'crazy', I'm more interested in overlanding. I just don't want to be replacing bushings in 8 months because it wore out just from normal use.
someone with experience please inform us
