78 Dana 60 high pinion kingpin swap
Old Oct 29, 2012 | 08:08 AM
White-JKU's Avatar
Default 78 Dana 60 high pinion kingpin swap
This is not a thread to hate on the swap or whether its necessary or anything of the sort. Also, not a build thread just a thread to gain knowledge and learn what others have done.
Well here it is, I bought a dana 60 78 high pinion king pin axle a few weeks back and have torn it apart to rebuild and convert it into the Jku. For my build I am planning on going with the Artec truss with many of their mounts. I am going to be getting a high steer kit with the king pin removal. I know I have to be missing something here. 5.13 gears locker etc will go in too. Running 40x13.50x17 inch toyos on this.
Here is what I am thinking so far and would like to hear input, thoughts, concerns, etc.
Start with the Truss:
Then the Brackets:
Adjustable Parahard mount:
Truss upper link mounts:
Lower control arm bracket:
Coil Correction (will notch and weld onto the truss):
Misc. tabs for shocks and more
Steering:
Now onto the high steer kit with the king pin spring eliminator:
West Texas Red Neck Ram:
Hydro steer cooler:
U joint replacement:
So what am I missing and what are the thoughts?
The other option would to go with a partial truss rather than a full length and then get mounts and brackets from Ballistic offroad rather than running everything off the truss.
Old Oct 29, 2012 | 08:32 AM
wells's Avatar
What's your plans for VSP and ABS?
Old Oct 29, 2012 | 09:12 AM
White-JKU's Avatar
For the time being go without. Haven't gotten that far and it's not at the top of my list
Old Oct 29, 2012 | 09:42 AM
isolated1523's Avatar
Hubs or lockouts? Staying with 8x6.5, or converting to JK bolt pattern? Other than the outers, and assuming you're going to run the same suspension setup (4-control arms and trackbar), you've got pretty much everything. I'll shoot you a PM with a nice easy solution to your ESP/ABS setup, if you're interested.
For what its worth, i'm doing the same swap when i get back from afghanistan---my 79 D60 is sitting in my garage. But i'm going with coilovers O
-Adam
Old Oct 29, 2012 | 10:55 AM
White-JKU's Avatar
-Adam
Selectable hubs, plan on keeping the 8x6.5 lug to keep prices down and yes the same suspension unless I win the lottery
Old Oct 29, 2012 | 12:11 PM
Rancho's Avatar
Sponsoring Manufacturer
Any plans to upgrade axle shafts?
Old Oct 29, 2012 | 12:27 PM
White-JKU's Avatar
Not at this point. If they break I will but until then no.
Old Oct 29, 2012 | 08:19 PM
D_engel's Avatar
I know a guy up in the chicago area looking to run a similar setup. Ill see if I could find his handle. I'm sure you guys could exchange ideas
Old Oct 29, 2012 | 08:23 PM
White-JKU's Avatar
Thatd be fantastic! maybe we could work together on the builds!
Old Oct 29, 2012 | 09:48 PM
D_engel's Avatar
ill get his info for you.
