2012 JKU Auto 3.21 gears and 35s
Old Oct 29, 2012 | 08:11 AM
flotto's Avatar
Default 2012 JKU Auto 3.21 gears and 35s
how many people are running this setup? I'm planning on doing a 2.5-3.5" lift then adding 35s. I know regearing is ideal but I have to do mods in steps. the jku is my daily driver.
looking for some opinions from those who have experience with this setup.
Old Oct 29, 2012 | 08:17 AM
JE8154's Avatar
I'm running the same set up with a manual. It takes a little to get it started but after that its whatever. It's too fast in 4lo, other than that its live able with a manual.
Old Oct 29, 2012 | 08:36 AM
danh63's Avatar
i think I am going that route and will regear soon after as soon as I figure out what I need
Old Oct 29, 2012 | 09:20 AM
Pregnant_Monk's Avatar
I'm running in a 2012 with a 3.5 AEV lift and 35 inch trail grapplers with 3.21 gears. There is definitely a noticeable power change but it isn't as bad as my 09 stock was so I am not planning on regearing yet. I'm going to put that money instead into bumpers and some rock rails. They are more important than regearing. IMO
ID:	383620   Click image for larger version
ID:	383621   Click image for larger version
Old Oct 29, 2012 | 05:38 PM
flotto's Avatar
so it's bare able then driving
Old Oct 29, 2012 | 09:33 PM
Yep sure is!
Old Oct 29, 2012 | 10:03 PM
Black_JKU's Avatar
Yup, same setup here..... No issues.... But I do have an auto.
I will not re-gear unless I go bigger than 37's
Old Oct 29, 2012 | 10:27 PM
FlameRedJK's Avatar
I've been running this setup in my 2012 auto for almost the past year. I used the AEV ProCal to calibrate for the larger tire and I think it runs like stock. I've never been at a loss for power.
Going up a steep grade, it Will occasionally be searching for the next gear in the higher rpms, but nothing major.
Old Oct 30, 2012 | 09:04 AM
flotto's Avatar
appreciate all the help. now I just need to pick my lift kit, then save for the tires.
Old Oct 30, 2012 | 09:26 AM
Originally Posted by FlameRedJK
I've been running this setup in my 2012 auto for almost the past year. I used the AEV ProCal to calibrate for the larger tire and I think it runs like stock..
would that ProCal help in any way on my manual ? My clutch is a PITA in traffic.. I find that my friction point is way to far and I have to slip the clutch. Forget a second gear start, it's stalls...
What about that little gizmo you connect to the behind gas pedal(don't remember the name of that gadget). Suppose to help throttle response.. Any opinion on that out there ??
