Noise when gas pedal released
Old Oct 31, 2012 | 08:48 AM
dellpjJK's Avatar
Default Noise when gas pedal released
When I'm driving between 15-70mph (the majority of the time) if I take my foot off the gas and let the engine slow the jeep down I get a funny sound that I can't really put well into words, but I'll try. Its like a rapid metal tapping sound, not from the engine, but seems to be from the transmission area. Maybe even something like a heat shield rattling rapidly but very consistently. I have a manual, and like I said it does it when my foot is off the gas and there is pressure on the drivetrain. If I put the clutch in there is no noise. Any idea of what it could be?
Other info: I also need to replace my ball joints, and recently had the passenger side U joint replaced, but it made the sound before the U joint was replaced... I was kind of hoping that would stop the noise when it needed replaced. It has 94K on it and has not had a clutch replaced. I'm not experiencing any problems with actual shifting or driving, just the noise. It's not loud enough to get a good recording, and if I have the radio on or we are talking you don't really hear it.
Old Oct 31, 2012 | 09:48 AM
Robar's Avatar
The thin metal heat shields around the exhaust. They make a vibrating sound if they come loose.
Old Oct 31, 2012 | 10:43 AM
wewpzee594's Avatar
X2 on the sound, last jk I think it was the heat shields. I need to crawl and take a look. Let us know if u find anything
Old Oct 31, 2012 | 11:35 AM
Miknov's Avatar
Old Oct 31, 2012 | 01:50 PM
dellpjJK's Avatar
Only when I'm in gear and foot off the gas though???
Old Oct 31, 2012 | 03:34 PM
themoneyshot's Avatar
but if the clutch is pressed the noise disappears. could that be a throw out bearing? or clutch plate issues?
Old Oct 31, 2012 | 05:11 PM
wewpzee594's Avatar
I hope not, 11000 miles new.
Old Nov 1, 2012 | 06:29 AM
dellpjJK's Avatar
Clutch in or out doesn't matter, it doesn't make the noise if it's not in gear. When its in gear it makes the noise.
Old Nov 1, 2012 | 07:58 AM
Juice Box's Avatar
This is cheap and worth a try:
I dont think you mentioned what model/year you have. I have an 07 jku 6 speed.
The exhaust crossover pipe that runs along the tranny support beam.... i had a rattle forever until i wrapped my exhaust with fiberglass heat wrap. You could just try a few hose clamps as tight as you can get them, around the above mentioned exhaust section. It has a flange welded to it that is known to rattle.
If this doesn't stop your rattle, at least you've eliminated it as the source and it only cost a couple bucks.
Old Mar 2, 2013 | 11:15 AM
tumlinson1's Avatar
Hey gents,
I am having the same issue... wanted to see if you ever came to a solution or found the source of the noise.
I have a 08 auto with 2.5 lift... 35 tires
Mine started with a growling sound when I let off the gas and then it started with the clanging. I took it out today to see if I could better define the source of the noise.
1. only happens when I get it past 40 mph and let off gas
2. noise stops when I am costing in neutral
3. 1 and 2 apply when in 4H
4. 4L it happens at low speed and even in neutral.
