Biggest lift without needing driveshafts
Old Nov 2, 2012 | 03:39 PM
Orange11jk22's Avatar
Default Biggest lift without needing driveshafts
What is the biggest lift I can run without lift I can run without needing driveshaft if I stay on the street till get the money to buy driveshafts?
Old Nov 2, 2012 | 03:46 PM
TURTLECON's Avatar
https://www.jk-forum.com/forums/modi...17/#post211274
Old Nov 2, 2012 | 06:36 PM
suicideking's Avatar
2". Some 2.5" lifts will work.
Old Nov 2, 2012 | 07:24 PM
TURTLECON's Avatar
I'm running 3" on my 08, zero problems on my front d/s so far. If you're pre-2012, you'll be fine at 3" and under.
Old Nov 2, 2012 | 07:30 PM
I go a 2.5 now but I have had a 5" laying at the house for year an a half and I'm getting the itch to put It on and was wondering if I could run stock shafts for a few weeks till I could get new ones
Old Nov 2, 2012 | 07:33 PM
k0260's Avatar
I'm at 3.25" of lift with no drive shaft issues. 3.25 on about 2 yrs now
Old Nov 2, 2012 | 07:38 PM
Bauker's Avatar
Been running a teraflex 4" long arm for 2 years now with stock drive shaft and no problems.
Old Nov 2, 2012 | 07:43 PM
Tonka_yellow's Avatar
You should be ok if you don't flex but Idk 5inches is a lot
Old Nov 2, 2012 | 08:31 PM
moz832006's Avatar
I'm running a 4" lift with 1.75" coil spacer and 1.25 body lift on my 2008 2door for over two years now. No problems on road or off. I mainly off-road in a sand dune area called red sands. Everyone said I had to change my drive shafts ASAP. I will, soon as I see a problem.
Old Nov 2, 2012 | 08:36 PM
JohnnyQuik's Avatar
The only right answer is it depends. I put 40k miles on my last JKU with 4" of lift and stock shafts. Both spline boots were torn or partially missing, but the pinion boots never tore, so I never needed to replace the shafts.
