rear track bar bracket.... better frame or axle mounted??
Old Nov 6, 2012 | 01:35 PM
LidLess07X's Avatar
Default rear track bar bracket.... better frame or axle mounted??
So I already have a frame mounted bracket that came with my basic 3" BDS kit. I am on a mission to improve on-road handling and ride comfort. Would there be any benefit in changing to an axle side one ?? Perhaps a Teraflex or EVO one? I believe the BDS was designed for the 3" specifically and I have a 1" spacer added to my coils.
Old Nov 6, 2012 | 02:30 PM
notsoricer's Avatar
is a JKS adjustable track bar out of the question? because that would ultimately be the best idea. but teraflex makes a good bracket that is for a range of lift heights.
Old Nov 6, 2012 | 02:37 PM
k0260's Avatar
I use TF's HD rear track bar mount. With just over 3" lift, I run it on the middle setting. Helps raise the Jeeps roll center. Works great.
