What size gears for bigger tires
Old Nov 8, 2012 | 02:15 PM
Loveit's Avatar
Default What size gears for bigger tires
I have a 2008 jeep jk with the 3.8 engine in it it also has the 3.73 gears i have recently installed a 2.5 lift with 295/75/18 witch is like a 34/11.50/18 i have been thinking anout regearing the jeep but not sure the trans kicks in and out of overdrive while driving so o jabe just been turning the overdrive button off dose anyone have an idea on what size gears i can uae to correct the problem
Old Nov 8, 2012 | 02:26 PM
TheTerminator's Avatar
Just press the button. It is easier and cheaper, and gives better performance, 'cause you won't likely regear to 5.38.
Old Nov 8, 2012 | 02:32 PM
tapp's Avatar
I have Toyo 315/65r16 and 3.73 gears. I hooked up a procal to it. It's fine. I hit about 2500 rpm at 70. It does kick down a gear going up hill but with the gearing its reasonable. I will regear when I up to a pro rock or a dynatrack
Old Nov 8, 2012 | 05:19 PM
gunbo75's Avatar
Do you have 2 or 4 door and a programmer.I have a 08 jku 373 auto with 285/75/17 and a Hypertech programmer and i am ok with it.
Old Nov 8, 2012 | 06:29 PM
tapp's Avatar
One more thing. You can spend $150 on a pro cal vs $1000 for regear. Try the cheap version first and go from there
Old Nov 8, 2012 | 06:42 PM
FoxRacingJMC's Avatar
I can get a good look at a T-bone by sticking my head up a bull's ass, but I'd rather take a butcher's word for it....
Do it RIGHT the first time. That's all the advice I got for ya...
Old Nov 9, 2012 | 09:00 AM
Jktough's Avatar
Insert "Tommy Boy" Quote here
Old Nov 9, 2012 | 09:31 AM
Old Nov 9, 2012 | 09:39 AM
sdyeti's Avatar
I put a 2.5" Teraflex on a 2013 four door with 3.73 gearing in the rear that came with the max tow pack. Added 35" tires and Bilstein shocks and used an AEV Procal to recalibrate the speedo. Rides better, and notice no difference in performance. The Jeep feels like it was made for this mod. Go for it!
Old Nov 9, 2012 | 09:48 AM
2008fx4's Avatar
2013 versus his 2008. huge difference.
personally id spend the coin and get gears. if you never plan on getting bigger tires, you could get 4.88s. i recommend getting 5.13s. allows for the chance you get bigger tires later on down the road. youd have to get a procal anyway to change the speedo for the new tires, it can correct for the gears too.
