Out of the country and i need help!
Old Nov 8, 2012 | 10:46 PM
emtclimbermatt's Avatar
Default Out of the country and i need help!
Ok so I'm out of the country and missing my jeep. I'm not sure where to post this so please re direct me if need be. I'm looking to put a custom switch panel in the center console of my 2008 JKUR, but I can't find any inside measurements for the console. If you have an 08 JKUR can you do me a huge favor and measure the inside of the console for me. So I can build the switch panel while I'm away hahahahaha thanks to any one who can help!
Old Nov 9, 2012 | 02:32 AM
Winterwheeler's Avatar
Default Foreigner
Where are you currently located? All you've said is where you aren't (not especially helpful).
Old Nov 9, 2012 | 03:21 AM
Jkcarmelindy's Avatar
If I had an 08 I would help u out but I do not sorry.
Old Nov 9, 2012 | 03:23 AM
Not sure if u read his post right or not.
All he is asking is someone with an 08 to take measurements of the center counsel.
Old Nov 9, 2012 | 05:40 AM
ronjenx's Avatar
What do you mean by inside measurement?
Unless you can pinpoint exactly what measurement you need, you'd be better off making the part with your JK present and accounted for.
Old Nov 9, 2012 | 07:44 AM
Delux2769's Avatar
I'll take some pics when i get out to the Jeep for ya in a few with my tape measure.
Old Nov 9, 2012 | 08:20 AM
Delux2769's Avatar
Here's what I just took pictures of:
Here's the top opening overalls:
Here's the very bottom:
And here's the tiny step in the front:
Hope this helps. If you need more, PM me.
Old Nov 9, 2012 | 10:38 AM
Juice Box's Avatar
The plastic cover of the A pillar is a good place for round rocker switches. Easy access and you can run wires from here to anywhere in or out of the jeep. I used a drill and a dremel, 3 switches look like they're supposed to be there.
There must be a reason why you want switches in your center console... 007?
Old Nov 9, 2012 | 10:43 AM
Tonka_yellow's Avatar
I ran my switches to the a pillar. I think its the best spot and easiest to mount them
Old Nov 9, 2012 | 11:20 AM
I work in Papua New Guinea
