diff covers with gear oil change
Originally Posted by Gman*2007
FYI. If you have a Dana 30 up front it takes 1 quart & Dana 44 rear holds 1.75 quarts
And yess i do have a D30
I just replace mine awhile back with ARB covers & lube lock gaskets and the front took exactly one quart and the rear one and three quarters. I replaced fluid with Redline synethic.
I just put ARB covers on mine with lube lockers. Follow the writeup and you'll be fine. When putting the oil in, I found it's a lot easier if you spend $10 on the hand pump attachment that fits onto the oil bottle and lets you pump the oil through a tube into the diff (kind of like a bottle of hand soap).
