What exhaust fo you have?
Well, I havnt been able to find a thread that covers just exhaust, so I figured I should start one.
I have the Gibson, dual exit exhaust. I like it for the most part, but one side always hangs lower than the other and it looks a little sloppy. It sounds pretty good, but even with a hard top on long trips, the droaning will drive you insane. So I am doing to try out MBRPs off-road single in aluminized (around $320) for a little while to see if I like it better, just cause. But if anyone has an exhaust you like, throw up some pics, and bullets on why you like it.
The one I have (not my rig)
The one I plan on getting.
I'm also looking to buy an exhaust. After many hours of research, I'm gonna buy the Magnaflow Performance Offroad Cat back. It dumps in front of the rear axle. It sounds like the Magnaflow is a bit deeper then the MBRP, and that's what made up my mind.
I have the regular Magnaflow cat back exhaust and i actually wish it was a little louder. It gets growling at mid to high rpms...but doesnt even sound like you have an aftermarket exhaust at idle
Dynomax makes an off road version (rock crawler) where the muffler is tucked under the frame in the middle. Mine originally dumped out the back but I chopped mine to before the rear axle. They now make one that dumps there without cutting. Cheaper than other brands and you can run it for 30 days and return it if you don't like it.
