Energy suspension trackbar bushings
Old Nov 12, 2012 | 06:54 AM
CCTEX84's Avatar
Default Energy suspension trackbar bushings
So I have slight movement in my trackbar just replaced bolts to 9/16. Still have slight shimmy over bumps alignment is fine. I want to replace my trackbar bushing to polyurethane but cant find them locally or online? Energy suspension makes them part 2.7104r any ideas??? I found one website autoplicity but never heard of em and oreillys carries them but have know idea how long special order will take? Any suggestions where to find these suckers?
Old Nov 12, 2012 | 12:21 PM
CCTEX84's Avatar
Anyone??.....
Old Nov 12, 2012 | 06:37 PM
Loadbreak's Avatar
Hvae you tried 4WD hardware or Quadratech? Both are venders here.
Try a PM to Bustabizz at 4WD and see what he can do for you.
Old Nov 12, 2012 | 06:58 PM
Delux2769's Avatar
Replace stock Trackbar Bushings!
HAHAHA
Ya... I attempted to do this with those bushings from Quadratec, and they do NOT fit into our Trackbars. You are much better off finding a new or slightly used trackbar for $25 off CL.
My father and I spent all night trying to get those damn bushings and sleeve into my original stock trackbar. If you look closely, you will see there ain't no way in hell they're going to fit.
My father's had to make his own bushings for several of his older Jeeps and we tried freezing and squeezing with a vice, then we tried melting and using a vice, and tried cutting them down to squeeze in there. They won't work.
Who knows, maybe there is a set of replacements out there for the trackbars, but I have yet to find one that works for our JKs.
Good Luck replacing it though.
Old Nov 13, 2012 | 07:26 AM
CCTEX84's Avatar
Well that's good to know after hours of searching guess new trackbar it is
Old May 15, 2013 | 04:36 PM
JK08MCS's Avatar
Default Energy Bushings
I'm a little late, but I got the rear track bar Energy Bushing's from Quadratec and they went in fine. Measured the front and thought they were the same
Energy Suspension 2.7105G - Energy Suspension Rear Track Arm Bushing Set for 07-13 Jeep® Wrangler & Wrangler Unlimited JK - Quadratec
PS: Looking for the polyurethane grease to use on my control arms and stumbled upon the thread.
Old Jan 19, 2015 | 01:46 PM
dtcercado's Avatar
Default Front track bar
I know this is an old thread but i just ordered a set for my front and rear track bar. Anyone change the front track bar bushings out? Any suggestions or tips for install? The back track bar bushings look straight forward because they are two pieces, but the front is solid one piece. Was thinking of using a ball joint press.
Old Jan 20, 2015 | 07:28 AM
dtcercado's Avatar
No one?
Old Jan 20, 2015 | 07:29 AM
tribulation138's Avatar
I have them and love them
I had to use my ball joint press to remove stock bushings
Sent from my SCH-I545 using JK-Forum
Old Jan 20, 2015 | 08:07 AM
dtcercado's Avatar
Originally Posted by tribulation138
I have them and love them I had to use my ball joint press to remove stock bushings Sent from my SCH-I545 using JK-Forum
Cool thanks for the response now I have an idea of task.
