Newbie to JK, critique my build plan
I just bought a (new to me) 2007 JK Rubicon. I want to keep a LCG, so my plan is to go to 35x12.5 inch tires. I would like to run 15" rims, but need advice on which is better: 15,16, or 17? and why? I plan on getting aftermarket rims with 3.75~4.00 backspacing (I don't care for the spacers) to eliminate rubbing at full lock. I also plan on putting metal cloaks all the way around to accommodate the needed room for articulation. I also plan on modifying the pinch weld in the rear and using bumpstops up front. I'm not opposed to a 2.5 inch suspension lift, but would like to avoid any lift if possible.
Welcome! So basically you plan to do the good ole 35"s with no lift trick.. You can get away with it as long as you do not plan to wheel or articulate at all. I would strongly urge you to throw on a 2.5" lift. Teraflex makes a great one. You may also find that the right lift will make your ride a lot more comfortable and handle better.
No articulation? even with the high line fenders? I know my uptravel will be limited due to the bumpstops, but the down travel should be good? Can you explain why it wouldn't?
Originally Posted by Igrok
Yeah, I am going to put the metal cloak fenders all the way around. I wasn't planning on changing the control arms since I'm not putting on a lift.
I am used to running 4.88's with the 35's that were on my TJ... As for wheeling it, I did just that on Sunday and I was quite impressed with the Rubi. It only confirmed that I want to leave the suspension alone if I can, but can definately have more fun with the clearance from the 35's.
