Leveling kit or about 2 inch lift
Old Nov 13, 2012 | 01:44 PM
big c's Avatar
Default Leveling kit or about 2 inch lift
If I get a leveling kit or 2 inch lift would I have to get a bigger floor jack. Mine Is not fancy and I know I could gain hight with blocks of wood but not interested in that. Just wondering. Looking at Tera flex leveling kit or ome hd 2 inch kit
Old Nov 13, 2012 | 01:52 PM
Ncb's Avatar
Ncb
What size jack do you have now? Are you worried about needing it for removing wheels? For wheels it should work since you lift by the axle housing.
Old Nov 13, 2012 | 02:46 PM
big c's Avatar
I couldn't tell you the size but its a 2 ton jack i know that. just a little thing and yes im concerned about lifting for taking off wheels. I was thinking it would be fine but I'm new to this and wanted to be sure
Old Nov 13, 2012 | 03:04 PM
1978cj7jk2012's Avatar
Your jack should be fine. Jack stands is where you might have a problem.
Old Nov 13, 2012 | 03:08 PM
Gman*2007's Avatar
I think it depends on what size tires your running. The factory or bottle jack should work just fine taking a stock tire off because you are lifting from the axle. If that makes any since.
Old Nov 13, 2012 | 03:38 PM
Ncb's Avatar
Ncb
I'm sure you'll be fine. Since you lift the axle for a tire change a suspension lift won't make a difference. If you go bigger than 35 inch tires you'll need a block of wood to use with the stock jack, or carry a larger jack.
Edit-
Gman- I didn't see your response. I wasn't trying to repeat what you posted.
Old Nov 13, 2012 | 03:47 PM
Gman*2007's Avatar
Edit-
No problem buddy. That's what is so nice about this forum. All knowledge & experiences are welcome.
Old Nov 13, 2012 | 03:59 PM
big c's Avatar
Yeah I'm going to use factory tire size for now so I should be good
