Wheel spacers.. YES or NO?
Old Nov 13, 2012 | 04:39 PM
maine07jk's Avatar
Default Wheel spacers.. YES or NO?
Do people just use wheel spacers just because? Just to give it a wider stance. Is this good or bad?
Old Nov 13, 2012 | 04:43 PM
swaite3's Avatar
With stock wheels it allows for wider tires without rubbing
Old Nov 13, 2012 | 04:48 PM
djbrew's Avatar
I've got 35x12.5's and yes, I added them just to widen the stance.
Without:
Name:	2012-11-11 10.57.15.jpg
With 1.5" wheel spacers
Name:	2012-11-11 10.56.49.jpg
Name:	2012-11-11 11.13.54.jpg
Name:	2012-11-11 10.57.02.jpg
Old Nov 13, 2012 | 04:49 PM
tribulation138's Avatar
i have 2 inch spacers on stock tires and wheels
Old Nov 13, 2012 | 04:53 PM
k0260's Avatar
yes wider stance, and allows use of factory wheels with large tires and no rubbing on sway links etc. I've been using 1.5" spacers for almost 3 yrs now. Running OE wheels with 35's, spacers are a must to keep from rubbing especially if you still want full clean flex. All in all, an aftermarket rim with 4.5" +- backspacing would be safer. Spacers are working great for me IMO ofcourse........
ID:	388476Click image for larger version
Old Nov 13, 2012 | 05:27 PM
DesertRat_Rubi08's Avatar
I just took mine off, done with em.
Old Nov 13, 2012 | 06:01 PM
Mike3488's Avatar
imo, one step closer to death wobble. I've also heard of people snapping lugs when offroading. I decided not to go with them after some google searches. But again, i dont have first hand experience. If you do, there are a few brands that are better than others. Either way, just be sure to research it.
Old Nov 13, 2012 | 06:17 PM
OhhSeven's Avatar
JK Forum Regional Rep
I've had mine on for 4 years. Not one issue. Reason I got them was to keep bigger tires from rubbing. Ultimately I'll be buying new wheels with the proper backspacing but for now I have more important things to spend money on.
Old Nov 13, 2012 | 06:22 PM
illestJK's Avatar
Just put mine on last week, I'm running 35/1250 Trail Grapplers and it would have been a tight squeeze without the wheel spacers. Makes it look a little more aggressive also, I love em
ID:	388497   Click image for larger version
Old Nov 13, 2012 | 06:25 PM
Just make sure you put Loc-tite on them when installing. Ran them for 3 yrs with no probs.
