ace sliders and rear pinch seam clearance
looking to install ACE sliders , however I will be trimming my rubi rails and rear pinch seams as I was rubbing on my last trip to Rausch. Can anyone advice if the ACE rails will need to be trimmed as well
Whack more than that off if you ever plan to go bigger than 35s. I took 2 inches off the rails and whacked the pinch seam back quite a bit also.
while were talking about the pinch seam, i was just going to post a message to see if i had anything to worry about with a 3" lift on a 2012jk and 285/70/17
i figured my tires are relatively small but i wasn't sure about adding the lift
matthew
matthew
