Bds 2 inch coil lift
Old Nov 17, 2012 | 02:11 PM
aftermath's Avatar
Default Bds 2 inch coil lift
Thinking of putting on a bds 2 inch coil lift with shocks on my 2013 jku. I have searched and find different answers. So wanted to post and see what you guys say. I'm new to the jeep world. I will be running 18x9 with 33s. I was told on a 2 inch lift that just the springs and shocks will do great I won't need anything else. What do you guys think?
Old Nov 17, 2012 | 02:29 PM
revvinkevin's Avatar
I'm no expert but I think you'll be fine. Maybe you could add longer swaybar links but not necessary.
Old Nov 17, 2012 | 03:15 PM
aftermath's Avatar
Oh I will also not be doing any heavy off road stuff. Maybe some trails but that will probably be it. Thanks for the reply and any other help ahead of time. Already getting more replies then I did on another forum.
Old Nov 17, 2012 | 03:21 PM
Tonka_yellow's Avatar
I would look into exhaust spacers. And everything else you should be good. How wide 33s and what's your wheel pack spacing
Old Nov 17, 2012 | 03:27 PM
BombJock's Avatar
I have a 2" BDS coil lift with 33s. The set up is fine for what you want to do. I have had mine wheeling in AL and also northern NM.
I did have some slight rear tire rubbing on my rubicon rails under heavy flex. No big deal, just a trim on the rubicon rails solved it. No probs now.
Here is a pic.
Good luck.
Old Nov 17, 2012 | 03:31 PM
aftermath's Avatar
I love the way yours is set up. What size wheels are you running? Ill get the exhaust spacer for sure I forgot about that. An ill probably go ahead and get the trac bar bracket. Ill be running 33 toyo open country with 18x9 I believe back spacing is 4.50 so tires will be 33 12.50
Old Nov 17, 2012 | 03:33 PM
Your golden then
Old Nov 17, 2012 | 03:41 PM
rockyjk07's Avatar
I had mine set up like that for a while with stock shocks it rode good with 33x12.5x15 when i went out to the dunes the tires would hit the rear fenders and broke like half the clips holding em lol
