Xd rockstar owners
Old Nov 18, 2012 | 06:41 AM
856kid's Avatar
Default Xd rockstar owners
I'm goon get the 20 rockstars but not sure if I should get 20x10 or 20x8. I'm installing 2.5"lift. X 8's backspace is 5.1 and x 10 has 4.5. I'm going with 12.50" tire so I am concerned about to much tire being past fender. Just wondering if 20x10 would stick out that much more then 20x8
Old Nov 18, 2012 | 06:57 AM
familytime's Avatar
JK Forum Regional Rep
Wow that's alot of wheel.What size tire are you planning?Anything small than a 38 you won't have much side wall
Old Nov 18, 2012 | 07:05 AM
Mopar2Ya's Avatar
I went w/the 20X10 because of the back spacing (& my tire choice), but IIRC there have been others who have the 20X8, but I can not verify if they also used a wheel spacer.
Old Nov 18, 2012 | 07:08 AM
Mrolson539's Avatar
I have the 20x10" with a 35x12.5" tire and they really don't stick out to far. Make sure to trim the rear pinch weld if you plan on going wheeling though. That was the only spot I had a rubbing issue with.
Alaska Jeep's Avatar
Here is the 8.5 rockstar with a 33x12.5x20. Sticks out about an inch past the stock fender.
Old Nov 18, 2012 | 07:16 AM
Dwight_Pollard706's Avatar
I'm running 20x10 with 35" Tires. Running 33's on a 20, Seems more streety to me
Old Nov 18, 2012 | 07:25 AM
jaker t5's Avatar
35's on 20x8.5 on a 4" lift they didn't stick out that far at all
Old Nov 18, 2012 | 07:26 AM
856kid's Avatar
Default Lift
What size lifts you guys have
Old Nov 18, 2012 | 07:27 AM
856kid's Avatar
Default Lift
Also, higher the lift the more it brings the tires in?
Old Nov 18, 2012 | 07:30 AM
** correction my rims are 20x9
My lift is a 4" lift. 3"suspension and 1" body
